I do agree, likely 2016 will be the "hottest year on record" especially considering this was a massive El Nino year.
Correlation is not causation.
It has been warming at more or less the same rate for the last few hundred years since the end of the little ice age. Graph 1 below the last 135 years. It is not disputed that CO2 increase in the atmosphere could not have had significant effect on Temp until after 1950. Yet you see a warming from 1910 to 1940 then a cooling, thus the 1970 ice age scare and then another approximately equivalent warming from 1970 to 2000. Since 2000 the temp by all data sets had been relatively flat. The IPCC report n 2014 acknowledges this pause. Thus any "warmest year on record" was only be hundredths of a degree. In your post you noted 2005 was hotter than 1998 but that only became true after last years "Pause Buster" study. The most recent Temp Graphs are different due to adjustments especially since last years "pause buster" study by Tom Karl where it turned out the temp at the water intake of ships is more accurate than floating buoys made for that purpose ( I kind you not). Point is no one knows what caused the warming from 1910 to 1940, the cooling from 1940 to 1970 but some how the warming from 1970 to present is known for sure to be climate change or AGW. Since we have been in a warming phase of which at least half is nature for the last 125 years then your 1/125 odds are meaningless. If it has been warming the last 125 years thus of course record hot years are more likely in recent years.
Of course CO2 is a green house gas and I agree with the science in that increased CO2 should cause warming but the details are important. Most people don't realize the majority of predicted warming is from feed back loops in particular water vapor. The earth heats up leading to water evaporation into the atmosphere where it traps more heat etc. Central to this theory is about 10 km up a tropical hot spot and increase in water vapor. Empirical evidence, that is data collected from weather balloons, satellites have failed to find it, this non existing hot spot is absolutely central to the feed back theory. Read the IPCC and current papers, the climate sensitivity continues to come down over time. There is back peddling going on behind the scenes. The models all predict much more warming than we have now.
So no I would not take you bet that 2016 will be the warmest on record considering it is almost over and the data certainly suggest that is the case. I would however bet you 2017 will not be the warmest year. I will however be fair and suggest that may not be a good bet for you considering 2017 is looking to be a La Nina year.
Also if someone were to ask me about the warmest year on record, I would respond first by asking, which record. As you can see from the ice core records in graph 2 it has been warmer than today for most of the last 10,000 years. So when you connect the warmest year on record with climate change you are connecting causation and correlation. Empirical evidence is what is needed to validate the theory and empirical evidence is sorrily missing. Empirical evidence is not glaciers receding, hurricanes, droughts, or wild fires. I don't know if it will get warmer or cooler over the next 10 or 100 years, no one does. I do think CO2 as likely caused some warming. I do know the the models have been a massive fail. CO2 levels have almost doubled and according to the models it should be a lot warmer. Like a blanket over the earth there should be trapped heat. No one can seem to find it. The models are wrong. No matter which data set you use they are wrong. We are looking at spending up to 100 trillion dollars world wide in the next 85 years to mitigate climate change based on models that are wrong. Could just 1 trillion dollars bring Africa out of poverty, cure cancer, house the homeless, or pay down national debts? Denying power to poor nations is subjecting those people to continued poverty and early deaths Global warming/climate change has been around for over 30 years now and no single proposal, agreement, or reduction scheme has so far made any difference. Even countries that went heavily into renewable are now cancelling subsides, like Germany building coal plants. Renewable are proving to be too expensive and still require full conventional back up. What is going to stop 2400 coal power plants. Trump is planning to go big on energy. There is a "denier" to be appointment head of the EPA. African counties want what we have. Our wealth came from fossil fuels. CO2 emissions are continuing to go up. Atmospheric CO2 continues to rise at a steady pace. It only slows down for recessions. We have already passed the supposed 400 ppm tipping point. There continues to be new discoveries of large deposits of oil. All I can says is we all better hope skeptics are right because I can pretty much guarantee government schemes have not and will not significantly reduce emissions. Renewables AKA wind and solar are diffuse and intermittent power sources. If we were really serious about climate change we should be building concentrated and reliable energy sources like nuclear and hydro dams like mad, . Until better storage comes along wind and solar are not up to the task. Local roof top solar can help a little but the big power uses are industry, buildings, hospitals etc.
New technology, the Boundary Dam project in Saskatchewan has found a way to remove CO2 from the stake of a coal plant turning it into added value products. Though it just proves concept it looks promising and affordable. I have read of other similar promising technologies as well. Time will tell. New coal plants are getting more and more efficient every year and new super critical ones may one day soon emit less CO2 than natural gas generation. These plants already element almost all other pollutants. These are worth investing research dollars into.
If you force not ready for prime time technology like wind and solar onto people then you are going to get what you got. If wind and solar were reliable and affordable then there would not be 2400 coal plants under construction.
About me
I have university doctorate degree. I am now in my 60's and live on a sustainable farm.My favorite PP podcast was the two vegetable farmers (it was a couple and cannot remember their names right now) in California who's practices I am trying to incorporate more and more into my farm. For fun I read stuff and got into reading about climate change about 3 years ago. I have read 1000's (really no idea how many) of research reports and papers. I can tell you there is a lot of bad science out there. After a while you get a nose for it. Lots of reasons like getting grants, publish or parish, conformational bias. I know the scientific process. One of my favorite scientists is Richard Feynman. "the first thing about science is not to fool yourself and your the easiest person to fool"
With regard to climate change the scientific process has gone off the rails. Why would 30,000 scientists including many Ph.D.'s, noble winners etc go out of their way to seek out and sign the Oregon petition. I suspect many of them see what I do. The right climate stuff. A large group of retired NASA engineers who are concerned NASA's good name is being smeared by bad science.
My journey starting with reading the climate gate e mails. You will soon understand that the whole climate change theory stands up supported by feet made up of a very few scientist, maybe a dozen or so. The rest of climate science assumes this information coming from GISS, NOAA, HADCRUT is well done and true. Read those e mails, see conformational bias, ends justify the means, controlling the peer review process, adjusting data, hiding data, poor handing and storage of data, erasing e mails, and refusing to release data. The vast majority of climate scientist are honest true hard working but their work depends on this work being correct and it is easier to get grants if your work relates to "climate change" . I suspect a lot of scientist know there is a problem but just choose to say nothing for a number of reasons. Anyway read those e mails and see what kind of people we are dealing with, it actually is shocking. If you don't have a scientific background it is easier to read book written by a someone who does.ie http://www.lavoisier.com.au/articles/greenhouse-science/climate-change/climategate-emails.pdf
After that I became a bit obsessed for w while and learned everything I could.
Graph 1
Graph 2
