Red stars in buildings are called Barn Stars. They were initially popular in the USA, among Amish and Mennonites, aka Pennsylvania Dutch. The tradition moved into the mainstream culture in rural areas.
These are usually made of thin metal or tin. The stars that s re used as an hors in brick buildings are quite heavier and tend to be painted black.
the same moment
before
the same time when a woman noticed ‘they are running’
take a look
cam turned off seconds before
shots
4k
okay, watch him when stops filming
#https://youtu.be/-LxUqeoI4EI?list=PLsbC53bZUNE95a6TaDSTuyt4FllaeNntr&t=479
videos from the same guy
oops
unfortunatelly no raw footage at shots fired
Thank you for sharing the video links. Sorry. it is not the evidence i was looking for. The authorities and the media have done a very good job of covering it up. Going to have to hope a rally attendee may upload something new in the future.
The FBI (Patel and Bongino) thinks that Crooks acted alone. The FBI has not even published exactly which ammunition Thomas Crooks is supposed to have used.
15:50
and they think, that Epstein killed himself.
28:50
2 puppets of the deep state
if you wanna see
#https://youtu.be/vkCV83HJGTs?list=PLsbC53bZUNE95a6TaDSTuyt4FllaeNntr&t=221
By the way, can you hear the muzzle report here?
#https://youtu.be/AN6RWoaDrKc?list=PLsbC53bZUNE95a6TaDSTuyt4FllaeNntr&t=363
&https://youtu.be/1uz6wrgRz0g?list=PLsbC53bZUNE95a6TaDSTuyt4FllaeNntr&t=363
I can hear it at the first three shots only.
I can hear Max’s 5 shots, not easily, because crowd noise is too loud.
Also, we have the shooter of Supersonic Shots 1,2,3.
His name is Baldy.
There were at least 2 shooters before Baldy, so Baldy may be called ‘shooter 3’, and Max may be called ‘shooter 4’,
Why does the muzzle flash look bright green?
Can a lead bullet’s “copper jacket” produce that apparent ‘green’ tone?
I’ve got raw footage of the 1.6 seconds, during which Baldy fired his 3, but I don’t see how that helps.
Marciniak and King should have stopped the show when HorseLady began her short ride, holding her flag, between the shooters(Baldy and Max) and Marciniak and King.
Nothing too vital here, but this is a higher quality shot than I had been looking at before, so I took a look at it. This was about three minutes before shots started.
I noticed at least four people watching from in front of the AGR 6 building - in spots that had no watchers one minute later. Zaliponi is there. Something is just right of where a window would be - something that appears to be reflective. People walk behind it.
The only thing that looks kind of suspicious is the window in the two story building that looks digitally painted over. It might be an artifact of digital compression, but so many other things are rendered reasonably well. We see the center window of AGR6, we see the window in the door of AGR6, we see all the ribs in the roof of AGR6 and the south 2 story building, hints of the ribs in AGR 9, and so on.
I can hear the first 3 shots, but not all of the subsequent 5.
The distance between them was probably so small that there was overlapping due to the loudspeakers.
But I’m not an audio expert.
Patel said “two of the investigations are obviously closed because the individuals are dead”.
Me - WHAT???
Patel: “There are two live prosecutions.”
Me - Again, what?
Bongino said (while blinking a lot, a common sign of lying) “In SOME of these cases the “there” you are looking for isn’t there.”
Bongino again: “If it was there we would have told you.” This is after they say they can’t comment on ongoing cases.
Notice - She didn’t ask, and they didn’t volunteer any answer as to why they haven’t produced ANY f***in’ information about a case that’s been CLOSED for 10 months now.
Yeah, Dan, you’re going to be transparent. At the LEAST he should stop the BS claim about being transparent. You all should check out the press release he put out on X after the shooting of the two Israeli embassy staffers. It was blah blah blah “transparent” blah blah blah “no ones in further danger”. He didn’t name the perp, even though the guy’s name was available elsewhere.
ribs = acoustic lattice, grating
@cmartenson
I found an interesting part in Feynman’s lecture - about the muzzle sound echo anomaly. However, he speaks about light waves, it is the same about sound waves.
According to simplified textbooks, we believe the light propagates alog a straight line. But those textbooks also mention the Huygens-Fresnel principle. Now we can imagine those “ribs” as acoustic lattice. And it can explain a very wierd sound propagation, too.
introduction
#https://youtu.be/w_6UROkeRQM?t=2523
Here he uses only a small piece of mirror, which will not work as explained. But he adds an optical lattice in front of it. And voila. (It is some pseudo hologram.)
grating - for one wavelength
#https://youtu.be/w_6UROkeRQM?t=2809
transcript:
46:36 what a net arrow I’ve got for the final result lots of light and so it’s
46:42 possible to take an ordinary mirror flat and cut away
46:49 strips correctly in the right places Just Right strip after strip very fine it turns out thousands of an inch
46:58 so that when you shine light down on it this way it bounces it off that
47:04 way this thing would only work with one color if
47:09 I’ve designed this very it’s called a grating it’s a line of lines and it works like a charm it’s beautiful if I
47:15 use red light and I’ve got that thing exactly right it’ll go right if I use
47:21 blue light it won’t work what I have forgotten to tell you in the beginning and I don’t know whether I said it last
47:26 time this is what happens with red light with blue light you get the same result
47:32 except the thicknesses are shorter all the timing is quicker and what the rule is for blue light is the
47:38 same as it is for red light except the speed at which you turn that for time is
47:43 faster you turn it more now you’ll notice that the place that we put those cuts was especially designed just for
47:50 this rate of turning if it turns a little more because it’s blue and I had
47:55 the cuts in the same place I made for my theoretical red one it turns out it all gets kinked up and it doesn’t work very
48:01 well but as a matter of accident it happens to be So that if I make two changes first I use blue light and then
48:09 I put the photo multiply at a somewhat different angle in fact less angle it works again with the same line that
48:47 the light is fixed you see colors red and blue I don’t know whether it’s come down in New Zealand or must have we have
48:53 them in the United States now on automobiles people have these wonderful colored signs that you wonder where the colors
49:00 come from they’re so bright and as the car moves it changed from red to green to blue and all they are is mirrors with
49:06 lots of lines on them instead of so they’re not reflecting in a normal manner all right so that is shows really
49:13 that we cannot get rid of the area which gives zero that it really is canceling out and if we do torturous and clever
Yes, they not only turned around, but also re-oriented their weapons - due to the increased threat level. They should have stopped the show, right at that time.
They found someone to be declared guilty.
We’ve seen footages about “someone is on the roof”. Before the shooting only Tyler saw the rifle. The first footage with rifle on the roof comes only after the officers overwhelmed that roof. And the rifle was taken away from the body.
(Several months ago I explained a situation when I borrowed an electric heater. My teacher stictly said to unplug it from the wass socket every time I go home. Because in case of fire the investigators might found it and simply say it was the reason. No matter if it was or wasn’t, they found something and stop the investigation.)
I didn’t realize there was so much recorded of his lectures. I won’t bore you all with reminiscences of Caltech, other than to say I went to Caltech’s seminar day 2 years ago after having not been to California since about 1989, and Caltech has been living in my head rent-free ever since. I have a part time job I don’t like that much, and my mind is wandering a lot - most often to those 2 years back in the 80s. It wanders to other events in the past, too, but those more than any others.
I’m afraid my physics knowledge never got good enough to take in much of his lectures except what would be called the popularized stuff. I could stand to look at MITs available content and see if I can still do some of that stuff.
The thing is, he said “the investigations” (plural) are closed because the individuals (plural) are dead.
For the purpose of an investigation like the Butler shooting, it wouldn’t matter whether a VICTIM died, so he must be talking about perps or suspected perps, right?
So what’s going on? Are they counting the guy that traveled to Washington, DC from Indiana to commit “suicide by secret service agent” an assassination attempt?
And then he says there are two ongoing investigations.
Is the Routh attempt counting as two investigations, is there one still open in Butler, is the case with Asif Merchant counted as one? What is he talking about???
To compound the weirdness, neither Roger Stone, nor Alex Jones, nor Doug Hagmann (the private investigator who’s been tracking the Butler case) has mentioned WHAT these guys have said. They’ve only talked about their “body language”.
fake audio
fake audio
X twit Evan faked audio, trying to suggest that Comperatore was hit with Baldy’s shot 3, apparently desperately hoping to keep that bullet out of Copenhaver’s abdomen.
