Having a store of clean drinking water is one of the most important and crucial components of resiliency-building and emergency preparedness. It has been said many times that a person can live for three weeks without food but only three days without water. There are many emergency situations and events that can cause your everyday water supply to become unavailable or undrinkable. The unexpected natural disaster or perfect storm will typically wreak havoc on the powergrid. When widespread power outages occur, water may not flow from the tap, or treatment plants may not be working to properly treat and deliver safe water. It is events like these that we all must prepare for. Here we explore ways to ensure you are prepared to meet these types of situations without much effort or concern.
Keep in mind the recommendation that you have one gallon of water per person per day for emergency situations. I personally try to store three gallons per person for my family to ensure that we have water both for drinking and for all the other activities in life that require water (cooking, dishwashing, sanitation, and water for the animals and plants).
Although there are many things to consider when developing a water storage plan, taking a few simple, low-cost steps to build up a store of water is easier than you think. The following ways to store water will hopefully provide you with the insights and methods to make the process a whole lot easier.
A few main considerations to observe before getting into the methods of storing water:
- Water can be stored for a very long time if prepared properly (6 months to 5 years, depending on the preparation method).
- Water is heavy and can take up a lot of space (one U.S. gallon = 8.34 pounds; 5-gallon container = 41.7 pounds plus the container).
- It is recommended that you have two gallons of water per person per day. Try to store a minimum of a 3-day supply. So for a family of four, that would be 24 gallons of water.
- Light and air are not good for water. For long term storage, always try to use opaque, airtight containers and store them in cool, dark spaces.
- To prevent water from growing bacteria and other bugs, use water preserver or bleach solution.
- It is recommended that you rotate your water once a year for freshness and check on your water supply every month to ensure that leaks or contamination have not occurred.
- Water containers can be stored in many different places such as closets, underneath beds, etc. Get creative, but keep in mind that a leaking container can give you a whole lot more headache than you planned for. Be mindful of possible water damage issues.
New Store-Bought Bottled or Packaged Water
![](https://tribe.peakprosperity.com/uploads/db0199/original/3X/f/b/fb09e677f969bfa96be757a9f5cc210ee4a3a2c8.jpeg)
Pros:
- Bottled water is available in almost any location in a variety of sizes. (1 - 2.5 gallons)
- Gallon-sized jugs can cost as little as $1, sometimes less, and can come in cases of 6. The heavy-duty cardboard boxes stack easily and protect the jugs from rupture and light exposure.
- Low upfront cost when buying bigger sizes (10 gallons for just over $11.00)
- Lighter and easier to transport. Good for emergency grab-and-go needs.
- Easy to store in cabinets and other small spaces.
Cons:
- Durability of bottles for long-term storage is questionable (would need to protect the floor from leaks if storing under a bed)
- Chemicals may leak from plastic containers during long-term storage (seek out BPA-free bottles if possible). It's not recommended to reuse bottles for drinking water.
- Not easy to stack one-gallon jugs and larger sizes
- Increased waste/recycling considerations
Glass Canning Jars
![](https://tribe.peakprosperity.com/uploads/db0199/original/3X/f/3/f316bf53d09041d6cea47af9dd4acdd12a7a6c9f.jpeg)
We keep three gallons of filtered water available in the pantry (stored in the original half-gallon case with extra cardboard padding between the bottles) and rotate them in and out by using them in the car as part of our everyday carry car kit (one gallon in the car at all times). The water is always fresh and there is no need to worry about chemical leaching from the container in hot conditions.
Pros:
- Easy to clean and sterilize
- Completely re-useable and can be used for other foods when not being used for water
- Recyclable
- Won't leach any chemicals
- Easy to see how much is left in each container
- Easy to pour
Cons:
- Jars are more breakable and can chip
- Expensive for the volume being stored
- 1/2 gallon jars can't be frozen for freezer backup like plastic bottles can
Heavy-Duty, Thick, Polyethylene Containers
![](https://tribe.peakprosperity.com/uploads/db0199/original/3X/f/c/fcd1622839baabba6e34fa7b683af3b61cf4a393.jpeg)
I have used many versions of these containers, and my current recommendation is the WaterBrick System. They come in a 3.5 gallon size that makes them easier to carry and pour from. As another advantage, their wide mouth allows for them to be used to easily store dry goods instead of water if desired, making them a dual-purpose container. The shape of the waterbricks also makes them easier to fit in tight places (under the bed, for instance).
Pros:
- Most containers/systems are stackable
- Reusable
- Durable thicker plastic (can be bumped and dropped without bursting)
- Most come with spout/dispensing options
- Able to transport in grab-and-go situations
Cons:
- Container cost can add up quickly when trying to achieve larger volumes
- Very heavy when full – (30 to 40+ lbs)
Bathtub Water Bladder
![](https://tribe.peakprosperity.com/uploads/db0199/original/3X/a/a/aaacf2f7b384394c7f00c631b52b3a0066b4fb38.jpeg)
Pros:
- Inexpensive and easy to setup
- Easy to store in the bathroom where you will need it.
- Large volume for multi-day supply of fresh water.
Cons:
- Disposable - can only be used once
- Water should only be stored for 4 weeks
- May be difficult to extract the water if the siphon pump fails
Outside Storage: Rain Barrels/Bulk Tanks/Pools & Ponds
This method requires the most planning and infrastructure investment, but also provides the largest volume available and longer duration of use when water is in short supply. If you are using rain barrels and bulk tanks for rainwater harvesting, keep in mind that water will need to be filtered and purified before using as potable water. Review the following articles by Peak Prosperity members about how they manage and setup their bulk water systems: | Rainwater Harvesting | Water Storage: An Example of Resiliency BuildingPros:
- Holds large volumes of water (55 – 5000+ gallons of water)
- Allows for rainwater harvesting and other free natural sources
- Easier access for both indoor and outdoor uses (supply for a garden, animals, fire protection, etc.)
Cons:
- Will require purification and filtration to ensure safety for drinking
- Usually requires additional infrastructure (solid foundations, pumping, piping, weather protection)
- Not easily moved
- Publicly visible water storage alerts folks of a water source during long-duration outages
I hope these ways of storing water have shown you that is easy to take the steps necessary to build water resilience into your life and prepare for the unexpected. Start small and build up your supply. And please post your own ideas and experiences in our comments section below, and share other ways you are storing water "just in case." Investing a relatively small amount of effort toward water storage can mean great peace of mind and improved success during an emergency.This is a companion discussion topic for the original entry at https://peakprosperity.com/5-ways-to-start-storing-water/
