Why sure.
I use a John Deere row planter behind my Mahindra tractor to plant the canola seed which I originally purchased from a group at University of Kansas (similar geography to my farm) where they were testing canola for best oil production in our conditions. There’s a name for it, but I can’t think of it right now, KU-XXXXX something or other.
I irrigate the crop when necessary (not often) with the 3 acre lake I dug up the hill from the field. I put a 4" pipe thru the levvvy over to the top of the field with a valve on it. The pressure I get with all that water weight is quite a sight! The lake is about 25’ deep where the pipe is, and is about 50’ above the field.
I windrow the canola when it is ready to be harvested with an Allis Chamlers mower / conditioner being pulled by the Mahindra. The conditioning rollers are set loose to eliminate seed breakage.
I then let it dry in windrows unitl the average is 10% moisture. Usually 2 days to a week. I say average because the canola does not mature at the same time from the top to the bottom of the plant, so there is going to be a variation from top to bottom and row to row as to the actual oil content in each seed.
I then harvest with my AC All Crop 66 PTO Combine. This will clean the seed so well that it is ready to go directly back into the planter or press without further processing. Again, this is pulled and powered by the Mahindra.
I then let the seed dry a bit more using air and sun - passively.
I then use the PTO off my Kioti tractor to drive my screw press. The way to get a good oil delivery from a screw press is as follows:
Start out slow with the jaws wide open. This doesn’t press so mush as start to crack the seeds open and get a good slush of seed, oil, and husk going. Then, once it’s really well lubricated up from the oil, I slowly start to crank it down until I get good oil with no husk. At this point I can go one of 2 directions.
1 - trying to keep oil in the seedcake for animal feed - just speed up the tractor and run it.
2 - trying to get max oil and dry cake - close it down more, keep speed low, measure temps on the output oil and don’t let it get too hot. 160* F is too hot.
#1 will give you faster production and better feed. #2 will give you more oil.
Everything you just read is powered by a diesel engine.
I’ve got pics and videos of all this stuff, I just don’t have them right here. JAG and others have seen the pics, and Aaron Moyer has seen it in person, so hopefully we can get past this sticking point that I am not really doing this and don’t have a clue. I’ve got well over 100,000 miles on grease under my belt. I may not know crap about gold, inflation, or derivitives, but this is something I do know.
Next you will probably have concerns with the amount of farm gear that is needed. Again, I would ask you to read the post in the spirit in which it was intended. That is:
People who are farmers already have this gear
People who are just starting out, the target audience for this post, will not. That is why I focused on WVO and the process rather than the farming. You notice Robbie didn’t ask how to grow or harvest a crop - he already does all that.
People reading this are more likely to want to do BioD than SVO, since it does not require kits to be installed into the vehicle. This is not what I primarily do anymore, I use predominantly SVO. The post was written the way it was for the intended audience.
I will also say that you and I are coming from a very divergent belief set. Apparently, you think that at some point in the near future, oil and natural gas will be unobtainable, and we will be required to grow 100% of what is needed to sustain our families. I disagree with this at a core level. That being said, you can take what you like from this article, if anything, and fit it to your belief system. I do not think either of our belief systems are incompatable with this post. If you read the responses, you will see Lye can be made via hardwood ash (I just so happen to heat with wood in an outdoor furnace) and I mention that Ethanol can be produced in small quanitities as a replacment for Methanol for use in BioD within the post. I also mention to Poet that 2 - 3 acres does not justify the farming equipment, and he should partner with someone who already has it, or go the WVO route.
I leave about this time every Friday to head to the farm, and I don’t do much internet stuff while there, so this will be my last post for a few days. I hope I have put some of your concerns to bed. If not, we’ll pick up next week.
