I must apologise for contradicting you, but you are defining a point from a dust cloud, whereas the actual bullet mark is clearly visible in multiple videos, which were streamed live on the day of the shooting and posted shortly thereafter, on July 19th and 20th.
The bullet mark can be seen in the RSBN footage, 3 minutes and 19 seconds after the shooting, at 6 hours, 45 minutes, and 37 seconds.
Therefore, the impact height corresponds to the height of the bystanders, and not -4 inches lower.
Remark:
Someone had opened Pandora’s box. (I refer to Fico shooting.)
Léva is a small town. But its name also means left (the opposite of right).
And a translation mistake(?) the shooter either came from Leva -or- supporter of left side parties. Maybe a precisely arranged ambiguity (confuse and rule).
Anyway, Fico shooting has opened a new chapter in the history. (Crooks allegedly looked for it.)
People still discuss the JFK case. Several people would be more satisfied if there were a revealed second shooter, I guess. Why didn’t they come out with a 2nd patsy and probably everyone would shut up.
@offtheback can you provide the times for shots 9 and 10?
Shouldn’t you be using only the report time? Can you provide us both of them (crack and report) for all the possible sources?
In your video, you address the question of whether the shots could have been fired through the vent.
You then say that this is not possible because the results for shots 9 and 10 do not match this assumption.
Could you please explain in generally understandable terms why the localization of the first 8 shots should be dependent on shots 9 and 10?
Is it the speed of sound, which is always the same?
Can you rule out with your audio analysis that all 8 shots could have been fired through the vent without knowing which weapon and ammunition was used?
About the reverberations on source 4.
First, I will make a disclaimer that I’m not a sound expert, my knowledge is in aeronautics and civil engineering.
Second, I’m assuming that shots 4 to 8 came from Crooks.
That said, these reverberations have a specific frequency and specific length. I counted 57 waves between 21.825s and 21.923s (on shot 5).
That gives a period of 0.00172s and frequency of 581Hz.
The distance travelled in that period is 0.603m. Now that is distance I know very well, it’s close the metal roof crest of 600mm. But that could be coincidence.
Now I counted the number of crests in the path from Crooks to source 4 at bullet 4 to 8. I counted 56 crests, close to the 57 waves. But that could be coincidence.
Now I looked at the line of sight from Crooks to source 4 cellphone elevation. At shot 10 he sees Crooks, so he is slightly elevated from the roof. At shot 3 he is below the roof line. Maybe he is very close to roof line at shoot 4 to 8. But that could be coincidence.
Now let’s hypothesize a possible cause of the reverberations:
The shock shockwave from the report would cross the roof crests and at each crest create a void and a reflection. Those reflections would not reach Source 4 when he is below the roof line because the sound reach that point by sound diffraction that could attenuate those roof reflections. And would not be heard in Ross audio because there is too much noise or the reflections are not at right angle.
Does this make sense?
This makes a lot of sense to me. The standing seam pattern could definitely reinforce a frequency that matches its spacing, when you are near perpendicular to it. As you move away from perpendicular, the fact that the wave is propagating radially and a reflection off one seam is going to be at an angle and bounce down the seam instead of reinforcing the next wave would seem to quash it quickly.
I didn’t think of that. The reinforced reflections is actually a sound resonance.
I saw that, too. and black residue on the metal bleacher
Whenever I can clearly discern the report time, I use the report time. When the report is being “stepped on” by the crack, making it difficult to discern, I calculate the report time by using the formula that you provided.
Okay. Per your request, I added a new sheet called “cracks” the the spreadsheet on the file server.
HI @vt1 Here is a report timetable that includes shots 9 and 10. I didn’t include those originally as I feel they are fairly up for debate.
A few caveats.
  1. shot 10 seems to be suppressed. That doesn’t screw with snicks for mics in front of the rifle, but it really screws with the booms. It essentially spreads out the sharp pressure peaks at the beginning of the boom, so I am measuring mush. My confidence that I am nailing timing is low for reports and shot 10.
  2. shot 9 can also be difficult due to low signal level and high noise in some cases. I think I did better than shot 10. The nice thing about the earlier shots 1-3 and 4-8 is, because there are similar repeated shots, it is easier to bootstrap the group into alignment using waveform similarities, and we don’t have that here.
  3. not all the timings here are absolute with respect to video time. Particularly so where I had to record off a playing YouTube video. For DJStew, they drop the minutes, but the times are also based on filtered data, which has a lag of roughly 0.7 ms from the real data, but I just can’t see the reports accurately in the unfiltered data so we get what we get.
Source 1 2 3 4 5 6 7 8 9 10
S2 Fence 14.7458 15.6044 16.2792 19.0714 19.3274 19.511 19.6881 19.847 20.678 30.273
S4 Mover 17.025 17.882 18.56 21.3628 21.62 21.8047 21.9815 22.1422 23.0515 33.10325
S3 TMZ 3.6907 4.5445 5.2177 7.9982 8.2535 8.4369 8.613 8.7727 9.6905 19.7332
S6 DJStew 55.0078 55.8632 56.5392 59.3238 59.5792 59.7627 59.939 60.0985 60.908 71.052
S5 Root 2.599 3.453 4.1263 6.9085 7.164 7.3474 7.5234 7.6833 8.2868 17.819
S1 Podium 2.8105 3.6645 4.33771 7.1204 7.3758 7.5592 7.7354 7.8952 8.3899 18.5488
S7 Crowd 27.6693 28.5232 29.1964 31.9787 32.234 32.4176 32.5938 32.7535 33.361 43.3985
NTD 40.2103 41.0642 41.7375 44.5199 44.7752 44.9587 45.1348 45.2946 45.8473 55.8694
With this model, the localizations of the 10 shots are all inter-dependent. I have to choose one location for one shot as “ground truth”, and then the other 9 localizations fall out from there. So, the computed locations for shots 9 & 10 depend on what I choose as ground truth for shot 1. When I use the rooftop location, Shots 9 & 10 resolve to the ESU (SWAT) officer and the South Barn sniper. When I use the vent location, the location for shot 9 resolves to an implausible location near the light pole (shown below). We know this is not possible because of the police bodycam footage.
Yes, because I am using boom times for TMX, Podium, Cruiser, NTD and Don’t Run for shots 1 - 9, so bullet velocity does not come into play. Therefore, I rule out the wall vent and all other alternate locations for shots 1-8. I am very sure of this.
For shot 10, I am using crack times for all recorders except one, so bullet velocity does come into play. But when I assume ground truth for shot 1 = wall_vent, the TDOA hyperbolas for shot 10 don’t converge, and I don’t think there is any muzzle velocity that would make them converge. So, that also rules out the wall vent.
Another caveat to consider:
The geolocation of source 5 is not very accurate.
The good news with this one is it is stationary and far away from the source(s) of sound, so it should be relatively insensitive.
Are there any other models?
Why are you sure that your model is the most suitable?
You have published the raw data.
Have your calculations been confirmed by other experts?
I still can’t understand why the localization of the first 8 shots should be dependent on shots 9 and 10.
Let’s assume that shots 9 and 10 had not been fired. Then it should still be possible to calculate the origin of the first 8 shots using several audio recordings from different positions. Or is that wrong?
I will try to explain this.
Imagine a scenario with static recorders and with bullet been fired from one position. The delta from the time of arrived from the first bullet and the time arrival of other bullets will be the same on every receiver. Independent from where they are. In this case the method used by Greg will only tell that all the bullets came from the same place. But could not tell where it came from.
Now if you know were one of the bullets came from, that allows to tell when the first bullet is fired on each receiver. Now every other bullet fired from any other place can be positioned. In this scenario if you only have one receiver you can tell that the location is within a constant distance from this receiver or a circumference. if you have 2 receivers the location will be where the two circumferences cross each other that gives 2 possible locations. If you have 3 receivers you can be certain of the location.
That why shot 9 and 10 are so important because we know where they came from.
The method (TDOA) is little more than that because it looks only at time differences and the geometric place were the difference between 2 distances is constant is a hyperbole. And by that you cross the hyperboles of each combination of two receivers to find the locations of the sources.
I would like to reiterate my request to the forum for the height of the bystanders and the height of Trump’s ear, in relation to the rooftop from which Crooks was firing, which is positioned 15.4 feet above the AGR floor level.
Currently, the approximate figures are as follows: the bystanders are at 12 feet and Trump’s ear is at 11 feet, with the sea level of the AGR building set to zero. This indicates that the bullet was ascending (rising bullet), which strongly suggests the possibility of two shooters.
@howdoiknowthisinfo @vegaspatriot @sorey @brian60221 @sgt-raven @redranamber @kincses-zsolt @rough_country_gypsy
Hi @vt1 and @greg_n ,
Since you two are among the most proficient with audio manipulation/editing, I thought of asking for your help with an issue. Yesterday I finally decided to synchronize 5 bodycams and the PiperGrimley video on my own, in an attempt to better understand the senate’s report timeline and the undercover officers. While watching I was able to confirm cammo-shorts in a leadership position of sorts (he directs a trooper at one point, summons Greg, etc… on SERT teams, even a trooper or corporal can be the leader of a team, for instance, so it wouldn’t necessarily mean a higher rank… maybe). Then, after the discussion yesterday with @vegaspatriot regarding doors, and watching the dashcam footage and seeing Nicol exiting door 9, I remembered DJStewart’s video, a section of it when Cammo-Shorts, who wants to stay at the corner og AGR6, asks Greg Nicol to come join him at the corner. On that moment, I’ve identified some verbal exchanges, but the audio is difficult to understand in full. Could you guys (and everyone else, of course) try to improve our understanding of this exchange?
I’ve tried to isolate vocals in Audacity, but so far I couldn’t get much more than what’s below.
Do observe that hand gestures may improve understanding.
Cammo Shorts: Top or down ? (cont’d) unintelligible
Nicol: I WAS-??-THERE (I was in there or I wasn’t there?)
Nicol: First burst of shooting …(fence rattle sound)…won’t stop shooting
(won’t stop shooting, won’t start shooting or don’t stop shooting?)
Someone 1: (asks a questions), unintelligible
Someone 2: Yeah, did that happen?
About 3 seconds of pops, cracks, fence rattling
Pause
Someone 3: Hey Greg… unintelligible (asking a question)
Greg (assumed): I did.(?)
This video will play just before CammoShorts asks Nicol to come over. Which you can see on the dashcam bodycam at 18:13:49 (
BTW, this is a better picture of cammo-shorts.
Just so I’m sure what to work on, what time does the critical audio happen? From about 7:07 to when?
@brian60221 The total exchange goes from 07:09 to 08:14 (Greg leaves).
The “Hey, Greg” by the end of the exchange is at 07:45.
