I was just saying it because people here have been using 3000+ FPS for their calculations
Yes those numbers around 3000 fps would be accurate for 55 gr rounds.
That’s why the key questions now are
  1. WHAT WERE THE ACTUAL RECOVERED BULLETS?
  2. How far was Trump’s head from the microphone?
But difficult for an AR-15 with a 16" barrel to pull off.
Daniel Defense AR-15, using Hornday Match ammo at 75gr was getting around 2500+ FPS…
I just ran 223 and 556 across chronograph yesterday with my 16" barrel
556 - average velocity 3035 fps
223 - average velocity 2914 fps
223 commercial reman - average velocity 2905 fps
The rifle on the roof was not a 16" barrel.
So just to confirm, all of your 55gr ammo shot out of a 16" barrel went faster than 76gr match ammo?
Source???
Heavier ammo generally goes slower than lighter ammo. As you start to get into reloading, twist rate plays a very important part of velocity. A bullet needs to be stable, and if it spins too fast, it can literally come apart. 2500 is about where 77gr would be. Even more so than 556, buying 77gr would be much less apparent on the shelf. 223 55gr is by far the most common wt.
16" barrel is on the upper, and typically will measure 16" from the front of the lower to the end of the flash hider. The lower with an extended stock, will also measure 16". The rifle on the roof very visibly is longer from the front of the lower when compared to the lower section. While I can’t tell if it’s 18" or 20" (rarer), it is not 16"
76gr ammo performs better at distance, against wind. That’s why it should be preferred. But if he used 55gr then maybe that’s why wind caused such a variation on a moving target.
Using a quick eye test it looks like a 16" rifle lol
Cop in black uniform probably has SBR since it has a silencer. SWAT guy seems to have a 16" barrel, and when you compare it to the rifle on the ground it doesn’t seem to be smaller to me.
I can’t quibble with your average velocities for 77 gr. over 140 yards. It seems close enough as the bullet decelerates. However, 77 gr. ammo is relatively uncommon unless someone searches it out, and one would have wanted to target practice and zero with 77 gr. Could be correct, we don’t know.
My speculation is that it’s more likely the far more common 55 gr. or next the 62 gr. ammunition.
Here’s a decent chart with velocities and brands and weights to aid your calculations.
I agree, with the grainy photo we have, the rifle attributed to Crooks laying on the roof appears to be 18" or maybe 19-20" but it does not appear to be 16". Stock appears to be fully extended, at about 11" on my AR15s. Barrel looks to be 18" to my eyes. I’ll readily admit that I could be wrong, it’s a hard picture to assess with no context for size comparison. But extra length will increase velocities.
We must also remember it’s the average velocity over 140 (or more) yards. So while a 55gr bullet, for instance, might read 3200 fps at the muzzle, at 140 yrds it might be down to 2700 fps, so we’d want to average these velocities to around 2950 fps or so.
Good quick reference for brands, weights, and velocities:
There’s another side view of the rifle that shows the upper being longer than the lower.
I haven’t run the calculator to confirm that assessment, but in theory, that should be correct, but remember, it’s a slower moving bullet. AND, as I said, you have to look for 77gn bullet in a typical gun store. You’ll generally find it on the bottom shelf, and it is more expensive.
here is another one.
Yes, it’s supposed to be.
I have two 16" rifles sitting directly next to me, both uppers are longer than the lowers. That’s literally how the rifle is designed lol
So it’s possible, just low likely hood. Alright. Then we have to account for 55gr making the “controlled” shots miss due to wind and him using a shitty AR-15 with a basic red dot.
Yeah there’s multiple views of it, I don’t see what you people see
Thank you for the photo. Should be easy enough to measure it. Assume 16" from the back of the stock to the front of the lower, and that will get you close enough on the barrel length.
Just measured one of mine sitting here, stock fully extended is 11" but to the front of the lower receiver it’s 18.5."
So on the suspect rooftop rifle, on my computer screen, it appears to be a fully extended stock which meastures 3.5" from the tail to the front of the lower receiver. Making it 18.5" in real life. The entire barrel length from the lower receiver front to the tip of the muzzle device is exactly 3.5" making it also, 18.5" barrel with what appears to be a birdcage or similar type device. So we can conclude with relative confidence it’s an 18.5" barrel including birdcage type device.
What? You think an AR-15 lower receiver is that long? a 6 point fully extended stock on a lower receiver is only like 10"-11" dude lol what the fuck
Sorry for the stupid question but what is a birdcage device?
Designed to affix to the end of a rifle barrel for various intended purposes based on design. Such intended purposes could be to disperse muzzle flash to aid in concealing position, compensate for muzzle rise by redirecting gases upwards or forwards, direct sound forwards (such as a linear compensator), reduce dust signature beneath the end of the barrel for prone shooting, etc.
medium__0004_AR-15_Angled_0297
warcomp-ctn-5.56-on-rifle
I’ve literally never heard it called a bird cage. I always called it a flash hider, and my suppressors have a 1/4 turn quick release flash hiders so I can use it with or without.
barrel is shorter than the fully extended stock and lower receiver lol
Odd, that’s a long ago industry standard name for any type of milspec or similar flash hider. Here’s copy from a Aero Precision AR15 assembled upper:
"This complete upper includes our ATLAS R-ONE Handguard! The R-ONE handguards are designed with size and weight in mind, while still providing plenty of real-estate to accommodate any attachment needs the end user may have. Our proprietary ATLAS attachment system is a durable and dependable mounting platform, maintaining a slim profile while still providing the strength and stability customers have grown to love from Aero Precision handguards.
M4E1 Threaded Assembled Upper Receiver 12" M-LOK ATLAS R-ONE Handguard 12.5" 5.56 Government Profile CMV Barrel, Carbine Length Low Profile Gas Block and Carbine Length Gas Tube AR15 A2 Birdcage Flash Hider"
