From Google Earth I could estimate de distance between the roof vertical line as 0.6m, therefore the distance of 6 horizontal lines is 35’’ that is close to whole gun length.
The length from the frontal part is around 17’’
I just measured both of my 16" barrel AR-15’s with the stock fully extended on both, measurements came to a little over 35"
The probable muzzle velocity is 2800fps.
I re-oriented the image and made no changes to compress it or enlarge any section of it, just to make it easier to measure, and put a virtual tape measure on it for context. The tape measure is obviously not to actual size but gives reference.
My real AR15 buttstock fully extended to the front of the receiver is 18.5" for context.
In this image, the ruler shows 4.25" from buttstock to front of receiver, and 3.75" barrel chamber to tip. That would translate into approximately 17" to 18" in my opinion. Looks more like 17" to me. I think we can narrow it down to 16.5" to 18" with the muzzle device.
However, these are crude measurements and being off by even an inch would throw the entire calculation out.
measured rifle
Considering this post: Audio Analysis Is Most Consistent Two Shooters At Trump Rally - #425 by bigtim
The most probable is 16’'.
In my experience, pre-pistol brace era (from which this rifle was apparently purchased circa 2012), gun companies universally built their barrels to at least 16.25" or 16.5" to make ultra certain they were compliant with the law requiring rifle barrels be 16" long.
So the rifle in question might very well be 16.5" barrel with a 1/2 or 1 inch muzzle device.
jesus christ man, okay we’ll say it’s a 16.75inch barrel. sound good??
it’s unreal the lengths people have to go through to verify a basic thing you should be able to gather from just using your eyes, but even with picture evidence staring you in the face you still cannot admit it’s a 16" barrel. even if it’s 16 point whatever number, nobody would call it that except you, everyone else would just call it a 16 inch barrel. do you know why? because a 16 inch barrel AR-15 is the most common kind…
the specs I have seen referred to a DPMS A-15 of 2013
deleted
Thanks for doing that, @jmholford. I did some experimenting and found that with the changes that I made to the perceived recorder positions for shot 10, a different adjustment value was needed to put shot 10 on the south barn. The details are shown in the attached PDF file.
Adding snick adjustments to shots 9 & 10.pdf (656.0 KB)
To be clear, this does not solve anything. The analysis of shots 9 & 10 continues to confound me.
I made a video this afternoon that others may find interesting. It slows down the shots to 1/10th speed. I wanted to listen closely to the shots to see whether I could distinguish between the shorter “snick” sound of a supersonic snap as opposed to the smoother sound of the rifle’s report. This video plays the sequence of 10 shots twice. The first set is normal audio, and the second set has some digital filtering done to suppress the background noise.
Question: Are you Greg Nichols, and do you find it bizarrely coincidental that one of the suspicious characters is Greg Nicols? I’ve never in my life heard of or met a Greg Nicols and now on the same “case” there’s 2 people with the same very unique name pronunciation?
Chris, thank you for your coverage of this issue and so many others.
Is it possible that the videographer was on the side of the building during the first three shots and for the remainder came around the corner and now had line of sight to the guns?
High frequencies are very directional, much more so than mid and especially low frequencies. Have you ruled out this issue as a contributing factor?
Thanks again.
Thanks for computing the lat/lon for that video source. Unfortunately, since it only has shots 1-4 that really limits its usefulness.
RSBN was patching in the audio from the podium mic during that clip. So, unfortuately, it won’t be useful.
@pk2019, no I did not realize that. The file I used is called “LEO montage - Cruiser + Why not on roof.mp4”. I downloaded it from a Mega link that someone posted on this forum. It only has one audio stream in it. Where do I get the original video that has all three streams?
Experiment worth doing…
  1. Calculate (approx) circumference of Crook’s upper arm based on this photo:
  2. Find someone with same circumference and color of arm.
  3. Dress in same t-shirt.
  4. Arrange in pose as in following picture:
    Shooter's_arm
  5. Take photo from afar, zoom in, and compare.
  6. Buy skinny-armed model a few beers. (Happy to chip in).
The experiment would falsify the arm position as the reason for the apparent difference.
You’re right, but bear in mind that (1) they also depend on the strength (amplitude) of the sound; and (2) modern cellphone mics are omnidirectional and pretty good; (3) there were differences as well in the very non-directional bass frequencies.
You’re not going to get much of a difference walking a few meters recording gun blasts, even around a corner. But whether it is enough of a difference is valid, so good point.
It certainly is an odd coincidence! Greg Nichols (engineer) vs. Greg Nicol (cop). Life is interesting.
Are you being serious?? lol
I swear half of these weird theories would disappear if people just chose to look at the evidence available to them lol
Wow, @vt1 . Thanks for doing those calculations. Just to be clear, you use the estimated speed of the bullet to determine the angle of the sonic cone. From what I’ve read, the internal angle of this cone decreases as the bullet’s speed increases past Mach 1.
bullet 1
Let me make sure I understand all the variables in Eq. 12
b = distance from shooter to the closest point of approach to the audio recorder
Vm = muzzle velocity
h = distance from the recorder to the bullet’s path of travel
Vc = speed of sound
If we go to Matthew Pearson’s Dropbox you’ll see an “audio” looking icon in the lower right that lets you select tracks.
We’re not sure where the mics are. They might be front cabin (we’re probably hearing air conditioning) and rear cabin (to record what suspects say) and something else, not sure.
