Before you dismiss my use of the JCB hydraulic lift as a reference endpoint for the first bullet, you need to prove that hitting or penetrating the non-steel railing would divert the path of the bullet, because that is not what happened as shown below, i.e. the reason I say this is very simple and is explained below.
So let’s assume we agree on the following:
- bullet 1 hit the hydraulics of the JCB hydraulic lift
- the evidence photos I sent earlier show the height of impact to be very close to 3.12m, which is the height of the tractor
- the stands are made of aluminum and not stainless steel
In my model, the real shooter was a sniper using a sniper rifle and was shooting from an elevation of a bit above the top of AGR building 7 (coordinates -79.97010210316301, 40.859031733531), and the JCB hydraulic lift is at about 300 yards distance.
The video https://www.youtube.com/watch?v=XVQa42YI6LU shows a man using a rifle (Ruger M77 Hawkeye Alaskan with 300 Win Mag) with a suppressor. This rifle combination looks very similar to the MK13 mod7 that was used by the snipers on the barns behind Trump. He uses 180 grain Winchester Magnum bullets fired at 2850 fps to see how much 16 gauge solid steel metal plating the bullet would penetrate at 50 yards. 16 gauge = 1/16th inch = 1.6 mm.
10 solid steel plates of these add up to 10/16th of an inch (1.6 cm) of solid steel, and these are penetrated in a straight line without any deviation when fired at 50 yards with a 180 grain bullet at 2850 fps.
In fairness:
- the railings of the bleachers are solid steel, but a lighter material such as aluminum
- the distance at which the gunner of my model shot at Trump/the JCB hydraulic lift was not 50 yards, but about 300 yards
- these differences would still not support your allegation that a bullet that touches or penetrates the railing would change its path!
As an aside: when I read some of the comments on this forum, I sometimes really wonder if the people who make bold statements know what they are talking about and where they get the references for their claims from…
As I said before, I limit myself to making statements about something I know something about and have extensive proven experience with myself. So I will not do extensive sound analyses, for example…
For example, a few days ago I saw a comment from someone who apparently assumes that a bullet travels in a straight line and that you can easily calculate the height difference using the Pythagorean rules…
As you may have noticed by now, I have very detailed arguments and evidence for everything I say… I simply do not make statements without references. I have worked on many forensic cases, and none of my reports have ever been found to be incorrect or questionable.
As for your claim that the path of a bullet, such as the ones I assume were used, would have deviated from its path by hitting the side of the stands: show me the evidence you use to support this claim, because I cannot find any supporting data for it at all.
The railings of these bleachers were not made of 16 gauge solid steel, let alone 10 sheets of it. The railings were probably made of very soft aluminum (because those stands are not transportable otherwise). That is, a sniper rifle bullet would have easily passed through that aluminum and would not have deviated at all from its path to the JCB hydraulic lift where it ended.
In short: the height of the railing of the stand is irrelevant and the JCB hydraulic lift at 3.12m is a very robust and reliable end point whose coordinates we can determine very precisely!
So, what is the height of AGR Building X (which is the 2nd highest building of the AGR site and the highest building at the main AGR parking) at the above coordinates that you have put into your model?
I think you simply entered the wrong height for that building in your 3D CAD model.
If so, correct it.
No hard feelings and let’s move on.
However, if you did enter the correct height for that building, I wonder how you can explain that you can simply see this building from the lawn where Trump was standing…
