Maybe get in touch with the Congressional task force as well
Good idea. Like Clay Higgins? I made one attempt, but those guys usually set up their web pages so that they only hear from their constituents, which I guess is kind of reasonable. I’ll take another look.
Mike Kelly of PA and/or Jason Crow of Colorado. The task force does have some very accomplished people on it from what I can tell (and if this isn’t just another “dog and pony” show to placate the masses (i.e., “us”), they would be the ones I’d contact
That would quite easy to be done, but for an absolute time you need to know when the RSBN or any other livestream actually started.
That doesn’t matter in my opinion. They only showed hour and minute, but you can go frame by frame, check when the minute jumps to the next and you’ve got the seconds as well.
Who showed hour and minute? RSBN? Can you provide a link?
Even better, you need to know the shot time in the RSBN video and back calculate from that.
Sure, here we go.
6h33m51s into the video Trump is announced to the stage.
BREAKING: ASSASSINATION ATTEMPT ON PRESIDENT TRUMP AT BUTLER, P.A. RALLY- 7/13/24 (youtube.com)
Thank you @sorey and @vegaspatriot,
in the 30 fps RSBN livestream Sorey pointed me to, the first shot was fired at 06:11 pm ET according to the on-screen clock in the lower right corner.
Using kdenlive, this is at 06:42:55 + 2/30 frames (=67 ms) relative to the start of the stream. When going back to the moment when the digital clock transits back to 06:10 pm ET, the relative time is 06:42:21 +25/30 frames (=833 ms) The difference is 33.233 seconds and therfore the time of the first shot is 18:11:33.233 ±0.033 seconds ET. @RawDoku may just add a reference to RSBN.
The 30 fps police cruiser dashcam video 1382_202407131806_Unit5-0.mp4 shows 18:11:31 for the first shot at the status line on top. Using kdenlive again, the first shot rang at 18:11:31 +29/30 frames ( = 966 ms). Hence the cruiser clock was off by -1.267 ± 0.033 seconds
Mills’ Sony alpha-1 clock was actually off by -64 seconds. And this was certainly not due to a claimed network-breakdown or a even a wrongly calculated roundtrip-time, as a certain know-it-all immediatly knew for sure. In context of time synchronization the surname Mills (David L., look it up) should have rung a bell.
Properly and well derived :+1:
I recognised that as well at some point that the dashcam M500-010482 was about a second behind. I feel the timestamps of all these body-/dashcams have to be checked and syncronised. Actually they should have done that before they release and cause uncertainty. The least they could have done is to inform about it. But maybe they are really that incompetent and didn’t realise it?
Interesting man this David L. Mills, for sure would not have happened to him.
The thing with the Mills picture timestamp is truely curious, don’t think that just happens to a pro photographer like him.
Do not complicate. You can address the video by seconds (from beginning).
12:41
//https://youtu.be/Rr63RgGN-Yo?t=4341
12:42
//https://youtu.be/Rr63RgGN-Yo?t=4401
4401-4341=60
The simplest explanation is that they simply don’t care about exact timing, even tough that compromises their dashcam and bodycam videos as every-day documentary evidence in court to some extend. Brian thinks that at least the bodycams probably do not have a GPS-chip built in, and thus would have no access to a reliable time source. One should never assume purpose if negligence is sufficient to explain the cause. But there is also wilful negligence …
What makes you think Pearson and his team, or the FBI, didn’t adjust the times befor releasing the videos? Notice I said “adjust” and not “correct.” I’m just saying, and your post just made me think of that possibility. I wouldn’t put it past the FBI for sure.
Thank you for doing this. I was using 18:11:32, which was closer to the end of 18:11:31 like RawRoku pointed out, but that was close enough for what I was working on. Soon I’ll be analyzing Crooks’ travels across the roof and documenting all the pertinent related activities that I can using the dash and body cams. That will require me to determine the time adjustments needed for each. Your info on the dash am will give me a starting point for comparison purposes. So thanks again.
Where is the technical equipment manager when you need him?
That I didn’t even think of. But true, that’s also a possibility Mindboggeling!
I assume the time stamps are directly burned into each frame of the video stream. If that is true then one would have needed to change every single frame. Certainly not impossible, but an elaborate work to get it right.
So what you’re saying is it couldn’t be done easily after the fact, right? I’m just messing with you. I’m a proud “conspiracy theorist,” not a lunatic. :sunglasses:
Hey, I did not intend to say anything like this. You certainly can just overlay a programmatically generated time bar parametrized by arbitrary offsets, including the Parousia of our Messiah.
However, if there was intention at play, and if the intention was not simply to confuse the public but to demonstrate “proof” of certain coincidences, then they had to think hard about what they’re doing. For some reason someone preferred to overwrite the audio stream of the hoisting-cop (the roof climber) with noise and just left us with nothing official but the suspicious police cruiser streams during the most interesting timespan.
I don’t know anything about dash or body cam time features, other than Jon Malis had his set 12 hours off creating an am vs pm issue. I believe I read someone posting that they wouldn’t have satellite time links like cell phones, but could be wrong. I would think that having that, along with GPS tracking, would have tactical benefits. It does seem like the FBI or other nefarious actors would benefit from us having to deal with 12 different cameras all having different time signatures, if only just to make us work harder.
