But similar spectral suppression does occur in a few other places. Granted, it certainly isn’t happening often, but here is one good example I picked out:
This is the third audio channel at 1:43. What is happening here is some fairly quiet talking coming out of the radio, and you can see that it’s at a fairly low amplitude. However, briefly, all of the background noise above 4 kHz gets suppressed.
It appears that the speech here has a moment where there is concentrated amplitude at 700 Hz, and that seems to take energy away from the other FFT bins in the same time slice - the bins that were already weaker to begin with. With 16 bits of resolution, it seems like this type of thing should not happen, but it does. Why? My best guess is that it has something to do with the A/V compression being used for the recording. Compression causes artifacts on both video and audio. These artifacts are supposed to be so small that humans don’t notice them, but computer analysis can reveal them, right? I think these black areas are compression artifacts. @offtheback, it sounds like you have a lot more experience in audio analysis than I do, so what do you think? Could this be a result of the compression being done by the the cruiser’s recorder?
I realize this is a theory. Is there any video or images to back up this theory to explain why the difference in placement of shell casings?
Let me look when I get back to my computer. One answer may be that the source of the hissing noise is the radio channel, which, when it has actual signal, transmits that into the cabin instead of noise.
Audio and video coding rates shouldn’t be codependent.
And yes, frequency decomposition and selective frequency bin manipulation is part of some compression schemes, as the goal for compression is to remove inaudible sounds if you have to remove something. But this recorder doesn’t seem to be working that way, from lots of other examples.
What is the software problem here? To determine the boundaries exact enough?
Theoretically, you could clip a region of sound to a different track in Audacity, offset it, and then subtract it from the original track to illustrate this.
Here we need almost perfect phase alignment to the sample to make this work given the frequency content.
I think it may actually be doable. Certainly to within a few samples, and try several possibilities. I was timing the tracks manually to I think a plus/minus two sample error when I was investigating arrival time jitter as a fingerprint of manipulation.
The question we really want to answer is whether somebody chopped out some stuff and added gunshot foley. I confirmed that all 8 reports were so similar that they could be overlaid and the pressure waves (or whatever they are) were virtually identical, but I just don’t know if that’s expected or not.
I fully understand that, and that’s why I asked: you don’t have to do this in manually in audacity, but can do it in every programming environment able to read sound files. I’ll try to write a script.
I am referencing a theory, but I do not believe it is correct. However Chris mentioned it in a video due to the side sights visible on Crooks rifle. You can clearly see the side sights in this FBI photo of the weapon:
Greg,
I took a look at the time stamp you referenced. Similar dropouts occur in the other channels for the same time. In channel 2, they are somewhat overwritten by clipping, which manifests as broad spectrum noise. In channel 1, you can see it overwritten with other noise sources that don’t drop out (horizontal purple traces).
So I think this is an artifact of the police radio, which is amplifying static except when it is not…
BTW, with regard to your TOA analysis, it assumes line of sight between source and recorders. But if someone is crouched on the roof of the building behind Crooks, I would say no one has line of sight to that sound source except for the podium.
I was scratching my head for the longest as to why the TMZ path length was slightly delayed for shots 1-3 as compared to what you would expect from the podium timing. But if the shots emanate from the area just behind Crooks on the next roof, there is a huge two-story building blocking the line of sight path to TMZ, and once the sound has to pass around it, the timing matches up.
Might that be the one where blood was discovered?!
@pk2019,
If you are willing to program it, you can run a quick and dirty brute-force cross-correlation with a portion of the report 1 signature and the whole area of interest in the audio samples. We won’t mess with the means and variances and just assume we can scale the results by the value achieved when the report 1 signature portion exactly aligns with itself. We would just need to define starting and ending samples of the clip we want to correlate with. Here is some pseudocode.
Shot 1 Starting sample == SS1;
Shot 1 Ending sample == ES1;
Length == ES1 – SS1 + 1;
Sample range of original sequence == 0 to N;
Array of samples == Sequence[0 to N];
Output Array == Output[0 to M]; ** If array of samples is only N long, M can’t be longer than the original array minus the length of the shot 1 snippet plus 1. The audio here is really long, so just clip plenty past the last shot and select a reasonable M that will get you two seconds past the last shot. “0” could reasonably be about 1 second prior to the first shot **
Calculate scale factor
Scale_factor == 0;
For i == SS1 to ES1 {
Scale_factor += SQUARE(Sequence[i]);
Calculate cross-correlation
Step == 0;
For i == 0 to M {
Output[i] == 0.0;
For j == 0 to Length {
Output[i] += Sequence[SS1+j] * Sequence[i+j];
Output[i] /= Scale_factor;
And then plot the Output array. Floating point numbers should be between -1 and 1, but can’t swear that will be true as we have made a few approximations (like zero mean).
Thanks. I don’t think the video has been maliciously edited at this point. More likely is that the lower-resolution video is just that: lower resolution, with fine movements masked by the compression. For anyone interested, here’s a video explaining how mp4 compression works and how it recycles frames, which can mask small movements, especially at lower resolution:
Here’s another one: https://youtu.be/UX4IbiM7TX8?list=LL&t=91
(Also, if you make the video small and lower the resolution, to match the Ross video, the recoil becomes unnoticeable.)
He’s either reading this forum or we think alike because three things I’ve posted here have been reiterated later in his videos
I’ll say this and be blount about Gary at PT: you don’t need to be angry. He spread disinformation without a care in the world.
One, he tried to claim that a shot could not be fired from the 3rd window and clear the fence to reach Trump. He did that without any actual investigation or calculations to back up his claim. That is dishonest no matter how you look at it.
Two, he tried to claim that there were people in between the AGR windows and the fence at the time of the shooting. We all know that is a lie because multiple videos confirm it is a lie. So: two blatant dishonest statements from Ol Gary.
Don’t stress about Gary. He clearly has his own agenda and it isn’t the complete truth.
Well, the beard, the voice and the interview, he claims to be the guy who made that video?
Why do you have any doubts? I am open to any feedback.
@kwaka,
Could I trouble you for the actual original still frames that you used to make the enhanced, stabilized GIF? I would like to do some analysis and comparison but if there is a bunch of other processing larded on top it begs the question of what process caused what effect.
I already have still frames for the “low-resolution” version from Roger.
In the tmz video you can see a man filming himself moving from right to left in front of the camera.
That’s probably what happened when the blonde woman bumped into the cameraman.
That’s supposed to be this guy, but he’s standing next to the cowboy hat guy the whole time.
I think the TMZ cameraman is behind the tree and can’t be seen in the whole video of Piper Grimley.
Maybe I’m wrong.
Unfortunately, you can hardly see the cowboy hat guy’s face.
I have been thinking about how to do this, the only way I can come up with is to sequentially post each frame here.
I have spent over 2 days analyizing this movie, have a look at the below screen shot:
So Semper Fi is standing on the left side of Ross in this view, the lady with the blue shorts bumps into Semper Fi and he get’s into the camera of Ross at the moment of the first shot. He moves to the right side of Ross… This all adds up, unless redcap is making the movie…
Here is the interview:
Ross claims in this video that: “one officer did try to climb up the building…” now that the body cam has been released, it is impossible for Ross to have seen this police guy. His story does not add up…
