False. Image is terrible quality and looks heavily edited now. And give time stamps and images on both before and after for several seconds, and we’ll all see that there’s not any possible way for this occur in the allotted time. Furthermore, given that we continue to see reflections and the security tape that window is still in place and remains in place during every known image, or no significant gaps in known images to allow for the complex operation you claim occurred.
And this of course ignores the 9’ or taller bleachers and audience which nowhere in this window allows sufficient height to overcome this obstacle.
Also, I’ve asked THREE TIMES now and will continue to ask you until you answer. Please differentiate the reflections from Windows 2 and 3, which are nearly identical but you claim they are evidence Window 3 was removed/opened.
I just did the same correlation analysis as with the shots from the police cruiser dashcam requested by @offtheback, and used the video you mentioned above.
The result: only one shot out of 14 reaches a correlation coefficient of 1. That again was shot 4 which I used as a sound probe. All others care far below. I’ve drawn faint red lines vertically across all panels if the correlation was > 0.7 (if only for the reason that this level equates to the legal threshold for government agencies to get into action).
So, apart from the probe itself, no shot in this series of shots resembles closely to any other.
Yet a video with a stationary microphone and a machine firing a rifle would provide the ultimate test source.
Watch-sniper-xs_uK_nk5qs.mp4.wav.stream-1-shot-4-pulse-sample.pdf (10.6 KB)
Watch-sniper-xs_uK_nk5qs.mp4.wav.stream-1-shot-4-pulse+echo-sample.pdf (43.5 KB)
Watch-sniper-xs_uK_nk5qs.mp4.wav.stream-1-shot-4-pulse+echo-x-stream-1-s1-14-cor.pdf (7.5 MB)
Watch-sniper-xs_uK_nk5qs.mp4.wav.stream-1-shot-4-pulse-x-stream-1-s1-14-cor.pdf (7.8 MB)
Oops. You are right.
dc = (d2 - ε2)0.5
But it doesn’t change the result significantly for the case of of the 1st shot with Trump’s mic because the bullet is so close to his mic (1.07 ft).
For mics or shots that are further away it will make a difference.
But I discussed only the shot that hit his ear.
So the answer for average bullet velocity doesn’t change in that case its still 2622 fps.
Funnily enough I’m only on X because the account was created “for” me a long time ago without my consent, back when it was still Twitter, and when I discovered it promptly changed login credentials and basically abandoned the account. Recently I’ve seen certain things, information and video, being released almost exclusively on X, so I’ve logged back in and started browsing.
I will definitely keep a watchful eye on #PatriotsInButler , and if anything more comes up will be sure to pass it along.
Why would a “helper” have a “headlight” if the they were trying to be inconspicuous?
From what I can tell with rung count vs what’s commercially available, it appears to be a fairly new 8’ ladder, though it does appear to have been left out in the elements for some amount of time. And thank you RCG for continuing to investigate the site. I don’t think we can say for sure that the ladder was present the day of the shooting, but I don’t think we have enough evidence to deny that it was either.
For what it’s worth, why all of a sudden is this area locked down tight with security patrolling? If they had these security measures the whole time, we might not even be here discussing this issue. If these are newly installed security measures, to what end? What are they trying to secure from the public or average passerby? Are they trying to hide something??
should you encounter any footage taken from the left bleachers (red circle) looking at the blue triangle, that would be great too!
so far, I have not seen any footage that shows the first 3 shots from this angle…
what I am most interested in is the lower part of that triangle, namely the green John Deere tractor and the yellow JCB hydraulic lift.
I am trying to determine which bullet damaged the hydraulic lift.
so far I have narrowed it down to bullet 1 or 2, but there is no conclusive evidence for either of these two so far.
maybe this one?
yes, that is the right angle, but without the first 3 shots fired
I mounted the frames prior to the one in subject and it looks even more daming! Have a look at frame 3, it shows literly how the upper window is pushed out.
Timestamp, T-4:93 / all frames taken directly from Stewarts video
helper-pushes-out-upper-window-3
This is somewhat unsettling.
Either Dave Stewart’s X account has been deleted/suspended/consored or something. My search settings aren’t filtering anything out, already checked them, but his account appears to be missing for some reason… :thinking:
Can anyone confirm? @realdjstew724 is mia?
Edit: Retrospectively, I think the @realdjstew724 handle may be tiktok and not x. Still unsure…
I’ve another one or two. Both cut off just before, “out of respect of the wounded” or something to that effect. Then there is TMZ with a pretty high resolution take of the southern bleacher south-eastern corner, with shots. Correlation analysis may sort of fingerprint individual shots and eventually identify the shot number, if you’re after that.
I don’t know, maybe you should ask the helper that question.
In any case it is very good for us, because he puts everything into perfect contrast, by having a back light and we can see exactly where the upper window is on each movement.
Maybe he thought it was off, but accidently had it on the lowest dim level (good for us!), because 10 seconds before shot 10 he definitely turns up the dimmer and is looking for something? Maybe the 3 empty casings?
Screenshot 2024-07-30 055940
yes, that is the right moment, but it is looking the other direction.
ideally, the yellow JCB hydraulic lift should be visible like in this photo:
and indeed, the videos I have seen so far from that angle cut right before the first shots were fired and resume when Trump is buried under the secret service officers…
in this video you can hear the swoooosj sound of the hydraulic fluid being pushed out by the 3rd bullet.
it takes some time for that swooosj sound to develop, so the hydraulics must have been damaged with bullet 1 or 2, but so far, there is no video showing when exactly that spray started:
@howdoiknowthisinfo do you know a video showing a machine triggered rifle taking the sound from a stationary microphone and without much other other noise going on?
what are the odds?
the fast buriers of information bragged in November 2020 with their remotely operated sniper station…
add some shock absorbing stabilizers to the tripod and you have a very solid platform from which sniper shots can be fired…
the following is a demo of 10 year old technology… i.e., today it would be much more advanced…
the accuracy of these things can be improved by pointing a UV laser at the target that needs to be destroyed/killed/damaged/injured: someone points a UV laser beam to the target, the automated/remote controlled weapon looks for the UV-dot that is lit up, et voila, the bullet travels to that location…
is this what you mean by a machine triggered rifle?
they also have machine gun versions :slight_smile:
As an aside, what a cool device. Seems like it would be super helpful during war times. Set that up and you aren’t risking the safety of your fighters.
Plus, you can conceal it in areas where humans can’t sit and wait.
yes, and it never gets tired, does not need to eat anything else than ammunition and never goes on strike…
but, as you can see, it is not the most compact thing that one could put in a ceiling shooting from a vent as it requires quite some operating space and its cameras and radars and sensors need some reflection free area to do their job properly…
it is totally unrealistic to assume that this type of device could have been used in a confined space like a false roof or ceiling:
  • it takes quite some time before the next bullet can be shot after the recoil of the previous shot was taken care of
  • the radars, lasers and sensors of these devices require low to no reflection to operate properly
  • the device is much bigger than a human with a sniper rifle
  • the device cannot anticipate any miscellaneous situation that needs to be addressed
