Site Reconstruction of the Assassination Attempt
local resident visiting the building
says its much closer than he thought, easy access to the roof, and the roof visible from everywhere
From an overhead view, that A/C is further away from the breezeway than this perspective implies.
youtube: Daniel Davis/Deep dive
body cam shows and records officers arriving on the roof with Crooks. They count 5 shell casings.
This could be preliminary and maybe more was found later…
This is the bodycam recorded about 30 minutes after shots and about 30 minutes before the USSS (secret service) man arrived.
This could help get to the conclusion that the first 3 shots were from some where else, then crooks fired 5.
Also, a little while ago, they are talking about crooks white van. Seen before rally, under the water tower. Then found 10 miles away with explosives, after shooting. Eye witness in the neighborhood saw the van being towed.
Let me know if you have any questions
Keep up the great work Chris!
Nancy Barter 404-713-2733
Bodycam footage
Cell phone data analysis - ties crroks to fbi
https://x.com/OversightPR/status/1815446074342953076
I honestly don’t know if an order was given or it was just decided. A bunch of Butler ESU body cam footage was dropped today. I haven’t seen it yet. Hopefully some answers will be found in there.
This is potentially another path to the roof:
A/C → Barn → Roof
At 4:57 in the video the ESU officer says: “Watch out for shell casings. 1, 2, 3, 4, and 5” as he points them out
So where were the FIRST THREE?
Assuming a single shooter that is an idiot (it is difficult to fully account for the creativity of idiots), that might suggest that the position or rotation of the gun changed and that the shell casings landed in a different spot as a result of that. For example, directional sound energy dissipating in different directions and being absorbed or reflected on the roof differently. That might also account for some difference in the audio. Of course, other theories are still in play.
I hope this contributes to your research. I found this 3D recreation of the first shot most enlightening.
Starting at 1:13:13 minutes within this podcast, a 3D research study shows the first shot coming from the window behind Crooks.
This matches with Chris’s observation that the first shot sounded slightly different from shots #2 an #3.
Chris has labeled various microphone sources used in his acoustics analysis.
“Source Four” audio supports my theory that TWO Deep State shooters fired a coordinated simultaneous “first shot” which was much louder in the recording than shots 2 & 3. This was accomplished with a “countdown” into earphones or earbuds worn by the two shooters. One of the shooters only fired one round as it would have been too difficult to synchronize additional shots at a moving target. That single shot missed Trump but toppled a bystander wearing a red cap and light colored pants in the upper LEFT corner of the bleacher stand to Trump’s left as he faced the crowd. (*Bystander in upper left if you are facing the bleacher stand)
The first shot was TWO shots.
Someone shares drone video after going onsite afterwards:
(12m49s)
First 4 mins are the lead up to the site, then his drone video starts.
I discovered it because of this man:
(26m30s)
Same person who shared the drone video I just mentioned also shared this of the Water Tower area:
(3m47s)
one single frame in the entire video show 2 bullets side by side. i am guessing its a compression or quicktime issue and will look at it again on better tools. But it was an interesting jump. everything else looked fine. but some weird edges around the helmet cam.
IMO the two-story building at the far corner of the complex needs to be looked at as a possible location for the real assassin in addition to the ground story windows of the building on which Crooke was killed. Don’t the trajectories line up better with THESE two possibilities than with the windows in the two-story building overlooking Crooke? I think they do.
I see 6 bullet casings in that frame (two circles have two casings, two have one). Is that what you see?
I annotated the other casings. In addition, I put orange arrows where image artifacts are clearly visible. Not debunking the image, but it does give reason to look carefully.
sorry the 2x case is just a quicktime compression glitch. i dont see it on premiere. below is the frame i hv with 7x shells. 8th one is below bottom left border and u see it when it pans down
Then lean out the damn window and look to see if a shooter is on the damn roof.
What the hell did they think that they were there for?
It is all starting to make sense to me.
The first three shots that are acoustically different from the second set of five shots that were in rapid fire were probably fired with the barrel of the rifle over the apex of the roof. When the shots were fired the majority of the sound waves were unimpeded by the structure.
This is also consistent with the location of the three rounds being found on the South side of the roof and not located with the other rounds. After Crooks fired three deliberate shots, he probably retreated backwards during his lull in fire to lower his profile.
At this time, he popped up and fired 5 mores rounds with the barrel of the rifle behind the apex of the roof. The change of barrel location would cause the sound waves to come into contact with the metal on the roof causing them to bounce off in different directions. The roof has raised metallic beams. This would be consistent with the louder and more metallic sounds of the 5 shots being recorded just west of his location. The 5 casings that were noticed by the officer were in a location consistent with Crooks moving backward before firing them.
It then appears from the evidence that Crooks turned toward his right to start engaging the crowd on the ground. When his head was turned the USSS Snipers round looks to have impacted the left side of the very back of his head. I was not a direct hit in the middle of the skull because of the caliber of the USSS round used would have caused much more damage.
Thanks to Sen. Grassley releasing more body cam footage from law enforcement, I’ve been able to pull this sunlight-lit image of Crooks’ rifle from the rooftop, then rotate and enhance with AI upscaling and detail augmentation. Now it looks very clear that the rifle has a 1X red dot sight (no magnification) with a side-mounted AA battery holder. Take a look yourself and see what you think.`
