Regarding a screen going dark to lit while recording:
Is it possible the person had a privacy screen protector. When tilted at various angles this would appear dark to an observer from all bit a more front on view.
I finally found the Reuters almost-straight-overhead photo that HowIKnowThisIsTrue had spliced into a google earth photo, and did the same thing, except in a larger photo.
And yes, I know it looks like the “line” that’s halfway back to the media section doesn’t line up with the line on the google earth map - that’s true. The google earth satellite view was apparently done a few years ago, and the path across the middle of the audience area didn’t even exist. the path just off to the side actually seems to have been moved - except it’s not really a path anymore, so much as grass that’s not as dark. I lined up the path in the audience area so that if one extends a line to the AGR building it matches up on the right spot.
What I got from this is that the distance from the front face of the AGR building to Mr. Trump was about 5.5 times the distance of Mr. Trump to Mr. Copenhaver. Which - if I haven’t screwed up - means a straight line from the south bleacher back railing to Mr. Trump’s ear meets the AGR 6 building about halfway up the roof. A very inconvenient spot.
If anyone can RESPECTFULLY tell me what I did wrong, please let me know.
I disagree that the view is from Mr. Copenhaver’s phone, and your HowDoIKnowThis map helps aim the AGR6 wall bearings at Mr. Dutch’s position, so I’ll add his map to the /j13/Copenhaver_phone.htm page on my website.
Regarding the altitude, maybe the phone owner(Mr. Dutch) was holding the phone up higher than the rail.
Also, the Bald Man’s 3 bullets would have descended some distance, from a higher point on the roof.
Here’s 3 faces of enemy gunmen recorded by Tyler Collins(you can see which roof surface these guys were using, 38 seconds before Baldy fired his 3 shots…and a bald man is to the right of those guys):
Collins says at 18:11:03 “he is armed”
“Iris Tao” had to be to the left of the person who recorded “James Copenhaver”'s video. Envision what the view of the AGR building would be as you stand in the bleachers, mentally move a few steps to the left, and the view shifts as you see it shift from the “Copenhaver” video to the “Tao” video.
Also if you want to add HowDoIKnowThis’ map, here it is. The one I posted before was my work.
He did a lot of good work, putting all the audio source locations in.
Thanks for your map.
A line on it, from Copenhaver, north through Trump(green line below), aims at a spot clearly West of all 4 vertical vents:
18:11:03 seems as Collins runs south, then west, around his car, and I didn’t know that he’d ‘radio-ed’ while running.
I also don’t understand why he seemed scared enough to jump down, yet brave enough to run, exposed to the same danger he’d just jumped down and away from.
I guess that Tyler didn’t see that ‘group’ of enemy teammates in the shade, ~40 meters straight West from himself.
If Sheriff Slupe and Butler Police Department knew a rifleman was on the roof, aiming toward the obvious target, many people seem to be in trouble, if a civil case against them reaches a courtroom.
I’ve cropped the template so that people with 1920 by 1080 monitors can see it without reducing it.
I might try this again, in a landscape format so it can be bigger. As it is, one can see there are items on the stage, but not much else.
Both of your lines, but especially the pink line, point slightly too far East.
Both lines, I think, are slightly too close to the ‘red carpet’.
Also, do you see any pixelated faces in this frame from Collins’ roof encounter video?
No, I don’t.
How could this shot hit Corey?
Perhaps the gunman wasn’t close ti the edge to see him running.
We should know the location.
There are at least 6 enemy teammates on that lower roof surface, between AGR6 and AGR5.
There aren’t many pixels, I think because of the bodycam’s wide angle lens, but I can identify human ears, noses, and beady eyeballs.
If you don’t see them, can you accept that others, including me, can see them?
In this case, I think the gunman certainly was Crooks, because I see a long haired blond guy, in the same location, in Dayve’s frames.
My question is why Tyler escaped apparent danger, and then ran right into potentially more danger.
Also, on that ‘porch’ roof that Tyler Collins climbed, the short vertical well to Tyler’s left seems like safe cover for any shot from Crooks.
Maybe Tyler could join this thread and explain his behavior.
Until then, I’ll claim that Tyler Collins, all by himself, could have prevented a murder, and 2 serious gunshot injuries(not the ear, not the arm)
Those aren’t shots. I’m referencing the point of view of James Copenhaver and “Iris Tao” as seen through frames in their videos. I’m trying to get a definitive answer on how high that first audible bullet would have been if hit hit Mr. Trump’s ear and then the back railing.
So the blue line starts at Mr. Copenhaver, goes through Mr. Trump and ends up with what he saw past Mr. Trump - the midpoint between the two western vent pipes.
Similarly for “Iris Tao”, who isn’t named that.
After I refine the multiplier from 5.5 to 5.4 figure Mr. Copenhaver’s POV was maybe 13 inches above the railing, not 16 as I was originally using in order to get the lines to match earlier, and then adjust for the fact that Mr. Trump was leaning over a little more when he was shot:
I come up with an origin of one of those little triangles at the front of the roof of AGR 6. Ken Linke is exploring the idea of “loopholes” in the AGR 9 building. I think he’s on to something, but on the wrong building.
And yes, I’m working on my book, although Ken Linke is definitely going to beat me to it.
Television told you a ‘story’, and you swallowed it, like a Labrador Retriever.
Mr. Copenhaver, when recording Mr. Trump, did not view the 'midpoint between the two western pipes".
You can’t make a line from Mr. Copenhaver, through Mr. Trump, to even the far Western vent of 4 vents, with your own map!
Mr. Copenhaver viewed the AGR6 south wall completely West of all 4 vent pipes, as proven by your own overhead site map:
You are drawing the line right through the middle of the lectern. That multiplies 5.4 fold by the time it gets to the AGR building.
Without DJT or his lectern, the (west)stainless steel rail base seems to align, vertically, with the gray air intake duct, which looks very slightly East of the center of the 4 vertical vents array.
I aimed south from that center point to the stainless steel rail base, and then to a point on the bleacher, and it points at Mr. Dutch.
I think I’ve got reasonably strong proof that DiFrischia’s video with “Crooks” taking shot one is fake.
Look at this frame from a version of his video. On the top is a higher resolution version, on the bottom is a zoomed out version (not the same still). In both cases you can see a seam in boards on the top front of the wall just below his feet. You also don’t see any of the facade on the east side of the building directly behind “Crooks” - only off to the viewer’s left.
Also notice the position of the support of the building’s light.
Now compare to this still from Jon Malis’ video:
You can tell that the light appears to be only a little bit to the left of the position it’s in in DiFrischia’s frame. That’s because Mr. Malis is standing just a few feet to the left Mr. DiFrischia - you can see him in several points of Malis’ video.
But we see quite a bit of the eastern building facade in the Malis still. If you compare the features of the trees behind the building, you can see that DiFrischia is shooting from a lower point. If he were shooting video from that exact point after “Crooks” had been shot, all one could see would be his hip and his shoulder. DiFrischia has a slightly lower viewpoint after “Crooks” is shot, and all one can see is his shoulder. They blur it out anyway.
There are a lot of other things wrong with “Crooks” in that video too (glasses too low, hair too shiny, full mustache, clothes outline is too smooth, seems to be laying on non-sloped surface, no red dot on rifle, doesn’t move).
I’m just wondering WHY he bothered taking video from such a low vantage point after “Crooks” was clearly dead. Malis too. Wouldn’t you want to run up close to the building, hold your phone up high and get the best possible picture possible - if the cops weren’t nearby?
I’m also curious as to why none of the people in the video wonder if Mr. Trump is OK. I mean - they ARE supposedly Trump supporters, and clearly a shooter at a Trump rally would be aiming at Trump, right?
I’ve got a simpler method: Copenhaver was hit by supersonic shots 1 and 3, no doubt, and Crooks didn’t fire them.
Also, Crooks could have hit Trump’s ear, but the bullet could only have sailed WEST of the corner.
I stopped watching those TMC videos years ago. The redhat red beard guy(Greg?) interviewed by the blind BBC reporter also is a total liar.
Their only content is meaningless, because their only content is the non-shooting Patsy.
Regarding, their lack of concern for Trump’s health, most of them are Kamala voters.
