So close to the green line, the difference between muzzle blast and crack could be 0 milliseconds, in case Crooks had fired.
Greg also thinks that muzzle blast and crack can arrive there at the same time.
I did not claim that muzzle blast and crack would arrive at source 3 at exactly the same time if the bullet was fired from building AGR 9 and the muzzle blast was generated by Crooks.
I claimed that the difference could be as little as 1 millisecond in extreme cases.
That’s why I don’t understand what exactly you’re trying to prove.
Putting Crooks at 40.858227, -79.970476,
and the cruiser at 40.858206, -79.970153,
and the AGR9 shooter at 40.858952, -79.970163,
I get angle WCA = 89deg., and CW = 74’.
Making the generous assumption of v = Mach 3 (it’s probably no greater than 2.5),
theta_M = asin 1/3 = 19.5
theta’_M = 70.5.
phi = 180 - 89 - 70.5 = 20.5
The formula for the time gap is
(CW - BW)/c
and since BW = CW cos(phi) = 74*0.927 = 69
Correction: I made a Fingerfehler with the calculator!
time gap = 5/1225 = 0.004 sec, or 4 msec
which is good enough.
My apologies.
So to refute your theory, I’ll have to try another recorder.
In the “Don’t Run” video [ref] we can hear the crack from the mach cone followed soon after by the sound from the right JCB speaker, then the left speaker. Here is the video, playing at 0.1x speed:
As shown above, for the direct path from the mach cone, the crack traveled 75.5 m to reach the Don’t Run recorder. Looking at the audio waveform, we see that the sound from the right speaker arrives 34 ms after the direct path:
0.034 * c = 11.9 m 75.5 m + 11.9 m = 87.4 m
And that distance matches up well with the right telehandler.
The next sound is heard 50 ms after the direct path. 0.050 * c = 17.6 m 75.5 m + 17.6 m = 93.1 m
I don’t have the location coordinates for the left JCB telehandler, so I drew a line on Google Earth that was 93.1 m long, and as you can see in the image above, it terminates in a reasonable location for the left speaker to be.
For the first three shots, you should only check the recordings that are closest to the green line.
That is Source 3 (Mike DiFrischia). He can be seen in the Source 4 recording from behind, standing to the left of the tree. To his left is another man who was filming. His recording could also be considered.
In all other shots south of the green line, a crack should also be heard when Crooks fired the first 3 bullets.
Ok, and what’s your opinion about @offtheback claim, that the cruiser audio was manipulated?
I made a mistake earlier when I said “1.5 seconds”. It was actually 0.68 seconds between shots 2 and 3. Sorry about that!
I’d like to download the original source video for this. I poked around in your Superfly folders but could not find it. Based on how blurry Trump’s face is, I’m guessing that you zoomed in quite a bit, which would amplify any artifacts.
I watched your slow-motion video at least 30 times, but I am not seeing the wobbles that you mention. I think it’s likely that what you are observing is video artifacts due to the camera movements coupled with the phone’s stabilization algorithm. To demonstrate what I’m talking about, look at the lower-left corner of the video around the 0:17 mark. Look at the two utility poles to the left of the “JCB” logo. See how pole on the right seems to be moving with respect to the pole on the left?
Shot 2 happened when Trump brought his hand up to his ear, which is at the 0:04 mark. That places Shot 3 (0.68 seconds later) at 0:04 + 0.68 * 24 = 20.3, which would correspond to the 0:20 mark. I perceive the downward movement of the speaker begining at 0:27, though it certainly could have started dropping a few frames earlier. So, 7 frames after Shot 3, which is 7/24 = 0.29 seconds. Therefore, my conclusion is that the hydraulic line on the JCB handler was struck by Shot 3, hydraulic fluid began spraying out immediately and within 0.29 second we can clearly see the boom retracting.
Thanks. I made another one just of Copenhaver and his friend, put it on X minutes ago, and Elon quickly warned of graphic content.
I could easily cheat, by adding audio to a silent movie, but I won’t.
I’m simply claiming that the speaker rocked slightly at impact, and the speaker was falling as Dutch was falling, and before Copenhaver’s abdomen was hit.
Problems were noted months ago, by PhiphiTheFrenchie, that audio was missing !
So we’ll never know what else ‘TV’ did to the source.
Please remember that TV is trying to hide the truth, just as you seem to be.
I’ll put the only source I had in my main directory here:
I’m not hiding anything. I’m just pointing out facts to you. @phiphi-the-frenchie what is this missing audio that @flamecensor is talking about?
Thank you for sharing the video from Corey’s cell phone. I marked the shots on it and watched it at 0.1x speed. It’s clear to me that the speaker is stable until Shot 3, then it begins its descent. The hydraulic line was punctured by Shot 3.
I count 6 poles, including street light and other, and I know Corey’s phone was moving, and I know we’re guessing in which frame Dutch was hit, and in which frame Copenhaver’s abdomen is hit(because his arm ALREADY has been hit in these 43 frames).
Another ‘conspiracy theorist’, JD Wilcox, in Dallas, has claimed that the JCB fluid was hit by a bullet from northeast.
I hope I don’t have to use that, because I disagree with JD on that claim!
Observe these two poles around the 0:17 mark and you will see a small amount of “movement” that can’t possibly occur in real life. However, this is not an indication that the video has been “faked” or tampered with, it’s simply the result of moving phone + stabilization algorithm + video compression algorithm.
It’s resized 900%, so not easy to see, but Copenhaver’s friend seems close enough to have turned his head to hear Copenhaver, with left hand cupped near his mouth, say “I think I’ve been shot!”
Gray-haired friend also reacts, with his arm close to Copenhaver, and fluid and blood may have hit gray haired friend.
I think Copenhaver’s knees buckled at frame 33, but he’d already been hit in an earlier frame.
Copenhaver’s left eye ‘closing’, I think, was when he was hit, became unconscous, still standing.
OK, maybe stabilization/compression algorithms, or even an imperfectly secured pole, in a breeze.
How you would cope with Copenhaver’s eye movement at the 6 second mark of the MJTruthUltra video, is by being escorted out of the courtroom by the judge…
and you never commented about the ‘other’ fluid…the contents of Copenhaver’s abdomen hitting his shirt…from the INSIDE.
And you’d be further done if you tried to disprove the timing of Copenhaver’s abdomen shot, or his very-related arm shot, to a human jury in a courtroom.
